Joined: 16/09/2010(UTC) Posts: 410 Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Hi, I was wondering if anyone can decipher this paint code please.
TRIM: 0956-18E PAINT: 585-0211
It’s on an HG Kingswood utility. I believe it to be a fleet colour. Thanks
The HKTG Garage. The Home of HK HT HG Holden. |
I’ll get it for you later, if Dr Terry doesn’t beat me to it. |
All good. A mate found it for me. Suburban Yellow (SA) |
Used by Suburban Taxis in SA. They also later used Kawasaki Yellow 31853. |
Joined: 2/11/2017(UTC) Posts: 62 Location: frankston Was thanked: 2 time(s) in 2 post(s)
Hi HK, Phil Bartollo has a HG RACV yellow Panel Van. Is this a different colour too. You can ask Phil for the number if you need it. Cheers.
There is like 30 pages of Fleet customer colours with maybe 100 per page. Some are repeats (used by more than one customer) but still a massive amount. The paint code for R.A.C.V. Yellow is 00012. So if its Acrylic it will be 568-0012 as most of these double or triple digit codes I have in HQ-HZ look like 0091 or 0105 or similar, probably 585 prefix on HK and earlier so 585-0012. I don't have its combination code though. Edited by user Tuesday, 14 November 2023 5:45:11 PM(UTC)
| Reason: Not specified |
Originally Posted by: HK1837 There is like 30 pages of Fleet customer colours with maybe 100 per page. Some are repeats (used by more than one customer) but still a massive amount.
The paint code for R.A.C.V. Yellow is 00012. So if its Acrylic it will be 568-0012 as most of these double or triple digit codes I have in HQ-HZ look like 0091 or 0105 or similar, probably 585 prefix on HK and earlier so 585-0012. I don't have its combination code though. I've got combination number 915 listed as RACV Pale Gold (Fleet Colour) with shade number 0012. Dr Terry |
Thanks Guys, very enlightening and interested to learn about the history.
Joined: 29/07/2006(UTC) Posts: 763 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
I have a heap of fleet colour samples Suburban Yellow is probably in there somewhere. Wayne |
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin) |
It's not actually called RACV Pale Gold. Just Pale Gold as it is not exclusive to RACV. It was also used at least by Newcastle Transport and Haulage Co, and United Beverages Pty Ltd. Edited by user Friday, 17 November 2023 2:35:01 PM(UTC)
Joined: 2/03/2005(UTC) Posts: 488 Thanks: 3 times Was thanked: 7 time(s) in 7 post(s)
