Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Ive overhauled the master cylinder with a new kit as it had been leaking Bled the brakes in the correct order Still don’t have much of a pedal and the stopping power is ordinary Ive nearly got the foot to the floor to keep the vehicle from rolling Pads and hoses are ok No leaks in the system
Check the reaction disc hasn't fallen out inside the booster. Had this happen on a UC once (late one with Commodore cylinder) and it behaved like you describe. |
Joined: 6/07/2019(UTC) Posts: 355 Location: bayside Melbourne Thanks: 220 times Was thanked: 26 time(s) in 26 post(s)
Originally Posted by: holden05 Ive overhauled the master cylinder with a new kit as it had been leaking Bled the brakes in the correct order Still don’t have much of a pedal and the stopping power is ordinary Ive nearly got the foot to the floor to keep the vehicle from rolling Pads and hoses are ok No leaks in the system
you did put the seals on the right way? what you describe means that is a possibility |
