Fastlane
Holden Forums
Holden Technical Talk
T-Piece for Oil pressure ECU and GTS Gauge
Joined: 28/05/2016(UTC) Posts: 36 Location: Sydney Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
I found this conversation from a while ago and was wondering if anyone might know the exact part for the T-Piece? https://www.fastlane.com...h-for-308.aspx#post73426Today I learnt that the VDO 360.005 Oil Pressure Sender I have wont work for the 304 ECU so I need to get a suitable one, and I have a mechanical Autometer gauge for visuals (https://www.vpw.com.au/parts/AMT-3321). The engine wont be in the car when started for running in, so that means no dashboard. :-) Plus the dashboard is still in a cupboard somewhere. All tips or pointers are appreciated.
Old red 6 intake brass T works. See photos. This is a VP 5.0L going into a HZ cab-chassis with new J&P oil pump. This is basically a made up one which you can do with brass bits from a gas shop. Here is a red 6 item that will do the same job: https://www.ebay.com.au/itm/255957474510Edited by user Saturday, 13 January 2024 5:48:09 PM(UTC)
| Reason: Not specified |
Thank you HK1837 for sending the pics and the ebay link. :-) I found this part which looks like it might be the same thing. https://confitaustralia....is-is-npt-thread-not-bspThe URL has 1/8 but the description is 1/4 NPT. I guess it can't hurt to try it.
Fastlane
Holden Forums
