Fastlane
Holden Forums
Rare Spares - Holden
Console Insert Automatic Indicator HQ HX Black
Joined: 15/02/2024(UTC) Posts: 24 Location: NSW Thanks: 13 times
I'm after some information on this part: https://www.rarespares.n...ic-indicator-hq-hx-blackDoes it have a light in the gear indicator? Is there a pin on the factory T bar lever that fits into it to move the red indicator?
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
There is a lamp in the T-bar harness and a socket in the console insert that it fits into. The T-bar has a pin on it that drives/moves the red needle. You need the harness to go with the T-bar, it just plugs into the main HQ-WB or LH-UC under dash harness. |
Fastlane
Holden Forums
