Hey people, can anyone tell me the rear track width on both a HK Monaro and a VS Commodore? Cheers Waz.
If you are thinking of putting a vs diff in your hk you really need to measure the two diffs from axle face to axle face. Measuring track wont help as the two cars have differant offset rims which will give you a wrong measurment so to speak.I have modifi
Have a measure of a VB-VK large Holden Salisbury. These are about 25mm narrower than a HK. If you want to retain the drums you'll have to fit spacers between the axle and the drum, and use HQ drums unless you change the stud pattern to HK. It is tempting
