think my diff is in the process of going, It has been increasingly noisy of late and yes it has plenty of oil. Tonight i got out under the car and tried to rotate the tailshaft by hand and when it was in gear no movement. Out of gear it had about an inch of loose play (ie rotated that much) so looks like it has had it. It is a 336 banjo and has done some ks. Anyone know a good replacement diff or diff place in Sydney.
Diff Technics in Kogorah will rebuild your sals & do the necessary machine work to fit your sals casing with Borg-Warner 78 series internals for cheaper than sourcing & rebuilding it with obsolete sals parts.
Once done, you have a ready supp
Make sure its not the universals a fraction of slack there will lead to a lot more at the wheel.
