Mr Void Offline
#1 Posted : Saturday, 7 January 2006 11:11:06 PM(UTC)
Mr Void
Hi all,
Just wondering where I should put the electric fuel pump in the tonner?
Are there any problems mounting it off the chassis rail behind the cab?
Should they be covered/protected from rail etc...?
Where have you guys put your?
Cheers all
___________________
Why are you reading this, you should be looking up there^^
___________________
#2 Posted : Sunday, 8 January 2006 12:44:06 AM(UTC)
If you can, try to find a factory fuel pump mount, say off a VL Commodore to try to reduce the pump noise. I have fitted an EFI pump on the inside of the chassis crossmember that runs behind the cab. This gives some protection from the road and I also mad
Mr Void Offline
#3 Posted : Sunday, 8 January 2006 4:54:56 AM(UTC)
Mr Void
Yep, it does - Thanks Matt
___________________
___________________
