#1 Posted : Wednesday, 11 January 2006 4:09:47 AM(UTC)
hi all me again . I have a 78 hz prem wagon running a 308 on duel gas & petrol and have just had to replace the water pump and fuel pump. what i thought was the original motor turns out to be from a commodore, can anyone tell me if there is anyway of telling what year the motor is and is it true that hz's came with blue and not red motors apparently if what my mechanic says is true power steering brackets for original blue motors are like rocking horse (u know what) is this true or do i find a new mechanic.
classic oz wreck Offline
#2 Posted : Wednesday, 11 January 2006 4:28:02 AM(UTC)
classic oz wreck
new mechanic....how many power steer brackets do you want?
www.classicozwreck.com.au
#3 Posted : Wednesday, 11 January 2006 4:35:41 AM(UTC)
none but did the hz come with a blue or red motor
#4 Posted : Wednesday, 11 January 2006 6:50:23 AM(UTC)
HZ only ran the red motor. The WB ran the blue.
On the front of the block, above the water pump, on the passenger side, just below the manifold, will be some numbers.
Post those numbers/letters here & the guys on here will decode them.
Also, the
potfare Offline
#5 Posted : Thursday, 12 January 2006 2:12:42 AM(UTC)
potfare
re red or blue motor number on block reads 15h8
#6 Posted : Thursday, 12 January 2006 2:51:23 AM(UTC)
classic oz wreck
thats a date code 15 august 78...if you cant find the eng no look on rego papers...presuming its regoed..
#7 Posted : Thursday, 12 January 2006 4:42:31 AM(UTC)
1978 means it's definately a red motor.
#8 Posted : Friday, 13 January 2006 7:30:31 PM(UTC)
So how is it possible to fit commodore parts i.e waterpump ,fuel pump. Pulleys etc to a hz red motor
#9 Posted : Friday, 13 January 2006 9:11:18 PM(UTC)
A lot of the parts are interchangeable because the basic motor design is the same, heads block etc some changes were sump,water pump,power steer bracket etc.
if it ain't broke we can improve it.
Cheers Steve
#10 Posted : Monday, 13 March 2006 11:10:00 PM(UTC)
Hi, I'm having trouble deciphering my block. I would be very thankful if someone could help me out.
QT882364
10F7 (or the 1 is a T?)
Thanks,
Kevin
#11 Posted : Tuesday, 14 March 2006 2:26:03 AM(UTC)
10F7 is:
10 = 10th of the month
F = June
7 is 1977
QT is HQ-HZ Red 308.
#12 Posted : Tuesday, 14 March 2006 3:42:21 AM(UTC)
Thanks Mick! Much appreciated.
Looks like a fine and knowledgable community.
Kevin
