#1 Posted : Wednesday, 11 January 2006 11:21:53 PM(UTC)
I have just brought an XB coupe with a XC front end on it that i want to change back to XB.Can anyone tell me if i have to change the entire Guards or just the headlight surround panel and are the bonnets the same for XB and XC.
Thanx
XB351 Offline
#2 Posted : Thursday, 12 January 2006 1:07:49 AM(UTC)
XB351
You don't have to change the guards but XB guards don't have the indicator in them. Bonnets are the same.
#3 Posted : Thursday, 12 January 2006 1:12:04 AM(UTC)
Thanx mate
#4 Posted : Thursday, 12 January 2006 5:14:27 AM(UTC)
You will also need to change the bumper and find a stone tray.I'm not sure if XC guards have holes to bolt the stone tray to as XCs didn't have a stone tray.
If your car has driving lights you will also need brackets which bolt to the radiator support pa
Paul351xb Offline
#5 Posted : Thursday, 12 January 2006 8:30:01 AM(UTC)
Paul351xb
You will need the XB headlight brackets. The XB grille screw into them though you might be able to use the XC ones. plus you need the 2 brackets that attach to the top of the radiator support panel. I think there is also a slight difference between the
