#1 Posted : Friday, 13 January 2006 7:55:04 PM(UTC)
I have found rubber kits on the Superoo website for $795 and was wondering if anyone has bought one and had any problems with them not fitting ect.
Thanx
#2 Posted : Friday, 13 January 2006 7:56:31 PM(UTC)
Sorry they are to go on an XB Coupe....
XB351 Offline
#3 Posted : Saturday, 14 January 2006 3:12:46 AM(UTC)
XB351
If you find some decent one's? Post it here. I bought 2 sets for my doors. 1 from Rarespares and the other from Bill Thompsons Auto rubbers. Neither fit. The gauge of the rubber is too thick which holds the doors open and out of allignment. Due to the rub
#4 Posted : Saturday, 14 January 2006 8:55:59 AM(UTC)
Same problem I got a set from Rare Spares and they did not fit, I complained and they said I should get them checked by some fitting mob . These guys said I had fitted the wrong but they only fit one way so how can I do it wrong. Back to rare spares quote
#5 Posted : Saturday, 14 January 2006 9:27:13 AM(UTC)
I have bought many of their seals over the years and havent had a problem with fitting the seals. Providing you take your time and make the required adjustments in the strikers etc you wont have an issue..
I've also found that using their spray called
#6 Posted : Sunday, 15 January 2006 12:34:19 AM(UTC)
I HAVE HAD PROBLEMS WITH THIS ALSO BUT WOT I DID WAS WEN TO A WINDSCREEN SHOP AND BOUGHT THE SAME RUBBER THAT THE SEALS ARE MADE OF AND MADE MY OWN DOOR SEALS ALL YOU NEED TO DO IS PUT A BIT OF GLUE ON THE ENDS OF THE RUBBER WERE THE WILL BE I HAVE NOT HA
