Fastlane
Holden Forums
Holden General Discussion
V8 into UC in QLD... Have you done it??
Hey, Im posting an expression of interest on this forum for thoughts on a V8 for my UC. Ive had replies, good ones at that - plus a few pointers too! Now i need to find out if anyone in QLD has done it and been street registered in QLD. If you have done it, it would be helpful if you could give me some information on the following: What needed to be modified for the V8 to fit (Ex Starfire, currently running red 6) Did the brakes need to be upgraded? What else needed to be changed/modified? Thank you for your assistance (in advance!). Keith
If I were you, I'd consult with QLD Motor registry, they will have a list of their Compliance Engineers who will put on the right track.
I think emotions run high, when contemplating a new higher performance engine in a car. You may have to think a li
by the words 'outside the square' i was referring to the fact that i want to put something different into my UC. I dont know of any Alloytec's in a UC (or torana for that matter), same deal with the 327. Lots of ppl are putting 308's in there, 350's, ev
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
In NSW a 308 is easy. An Engineer would simply look at an LX and say the UC is the same car with different nose and tail, and has to comply with the same evolution of ADR27 ie ADR27A. Therefore a 308 would be a snack, particularly since there were 11/77 p |
Good suggestion Byron! Once im home ill hit the D.O.T and suss out what needs to be done, and ill speak to my engineer and see what he rekons! This wont be happening until about Mid-year, so i have plenty of time to locate and build the motor! Keith
Fastlane
Holden Forums
