2 Pages<12
RussVRute Offline
#21 Posted : Monday, 16 January 2006 4:21:12 AM(UTC)
RussVRute
G'day Olaf,
The tonners had a 444, not a 411, but I wouldnt suggest you put one of them in because I have one in the HX and it revs its little butt off,but doesnt go anywhere in a hurry, yes its good with a load in the back, hardly knows its there, but c
RussVRute Offline
#22 Posted : Monday, 16 January 2006 4:21:12 AM(UTC)
RussVRute
Gday Olaf,
The tonners had a 444, not a 411, but I wouldnt suggest you put one of them in because I have one in the HX and it revs its little butt off,but doesnt go anywhere in a hurry, yes its good with a load in the back, hardly knows its there, but cr
#23 Posted : Monday, 16 January 2006 4:22:46 AM(UTC)
Na I dont think any manual sedan had 411 and the 336 was used for manual since at least the EH. Autos always run a lower (numerically higher) ratio than manuals. The station wagons and commercials generally run the same as the autos. Actually isnt it 444
#24 Posted : Monday, 16 January 2006 4:22:46 AM(UTC)
Na I don't think any manual sedan had 411 and the 336 was used for manual since at least the EH. Autos always run a lower (numerically higher) ratio than manuals. The station wagons and commercials generally run the same as the autos. Actually isn't it 44
crowe Offline
#25 Posted : Monday, 16 January 2006 7:52:00 AM(UTC)
crowe
Go for a 3.08 ratio, Anyway if your running a 2.78 at the moment you may need the blue 9 tooth in gear box and white 20 tooth on speedo cable to correct your speedo. I have a 253 panel van, have a M21 and 3.08 diff. As most of my driving's on the open roa
crowe Offline
#26 Posted : Monday, 16 January 2006 7:52:00 AM(UTC)
crowe
Go for a 3.08 ratio, Anyway if your running a 2.78 at the moment you may need the blue 9 tooth in gear box and white 20 tooth on speedo cable to correct your speedo. I have a 253 panel van, have a M21 and 3.08 diff. As most of my drivings on the open road
#27 Posted : Thursday, 17 January 2008 10:14:51 AM(UTC)
Looking to Buy 4.44 Crown and pin Gears
to suit Large 10 bolt Sulsbary
Anyone Help Please
#28 Posted : Thursday, 17 January 2008 4:30:31 PM(UTC)
With an M20/21/22 and 3.08 diff you need a white (20T gear) with any of the standard HQ tyres except 78x4 tyres which use a pink (19T) gear. Try a pink gear and see how it goes. As a standard thing, AFAIK there is only the one size drive gear for aussie 4
basketcasebear Offline
#29 Posted : Friday, 18 January 2008 8:03:00 AM(UTC)
basketcasebear
hey yall.
i have a 308t400 336diff 15inch wheels, and am trying to get 70,s high tyres. i am wonderin what sort of balance this will give me?
any ideas welcome.
ptpro
some men see things as they are, and ask "why"
I dream of things that nev
DOH!!!
2 Pages<12
This page was generated in 0.066 seconds.
