HQ
#1 Posted : Friday, 26 January 2007 4:43:59 AM(UTC)
Hi can I fit a HZ chassis into a HQ sedan.Thanks.
#2 Posted : Friday, 26 January 2007 5:01:06 AM(UTC)
Hi I should add that I am in NZ so have no hassles with certification if it can be done.Just doing up an old Prem so thought the RTS would be good.Thanks.
Munromad2004 Offline
#3 Posted : Friday, 26 January 2007 5:02:18 AM(UTC)
Munromad2004
Yes, but check with the rego authorities first as I have heard that they use the number stamped on the frame rail as the identifying number for the vehicle.
Hopefully others can enlighten both of us on this point, but the frame will fit and as a bonus
#4 Posted : Friday, 26 January 2007 6:12:48 AM(UTC)
If ADR27A and registration is no problem then go for it. They are essentially identical. You can even use a WB Statesman one except only 2 x bumper bar bolts on each side can be used.
If we all h
#5 Posted : Friday, 26 January 2007 6:07:36 PM(UTC)
fit up a HZ rear swaybar to complete the package.
#6 Posted : Saturday, 27 January 2007 2:47:15 AM(UTC)
Thanks for the replys guys your comments are appreciated.
