#1 Posted : Saturday, 27 January 2007 11:37:07 PM(UTC)
im chasing part numbers for a camaro uni joint that fits the diff yoke and tail sharft dimentions the uni fits 2 cheers all
ozchevy Offline
#2 Posted : Sunday, 28 January 2007 4:16:29 AM(UTC)
ozchevy
Sorry mate,
Will chase that up for you this evening.
I've had a bad week - had an engine transplant to do in the family Tarago.
I'm still having problems, went from engine to clutch, to front drive shaft bearing, to noisey camshaft bearings - as in DO
Sandman Offline
#3 Posted : Sunday, 28 January 2007 5:14:05 AM(UTC)
Sandman
Why don't you just grab some verniers and measure the old one if you have it. If not, just measure the yokes and local parts supplier should be able to match it.
#4 Posted : Sunday, 28 January 2007 7:13:50 AM(UTC)
our local supplier of parts is useless not to mention a rip off ozchevy knows his stuff id rather talk 2 people that know ,plus if i can get part numbers then i know im getting the right 1. im in the process of setting it up for my monaro so infomation ab
ozchevy Offline
#5 Posted : Sunday, 28 January 2007 9:21:53 AM(UTC)
ozchevy
Thanks for the kind words htv8coupe,
Front Yoke assembly sleeve P/N VS12142
This is the sleeve to fit into your Turbo Hydro
Auto trans.
Uni Joint to fit your 10 Bolt Posi-traction is
P/N 6676987
Hope that gets you going with it,
Cheers.
#6 Posted : Sunday, 28 January 2007 7:36:42 PM(UTC)
well you have done it again you helped me i wish there was more people like u and as 4 the kind words im just being honest i hope some day i can help u with some thing some day thanks again
thank u 4 your time
This page was generated in 0.131 seconds.
