2 Pages<12
RussVRute Offline
#21 Posted : Thursday, 26 January 2006 9:33:42 AM(UTC)
RussVRute
G'day Kev,
Sorry, slight oversight there they are NGK BP6EFS-13( I think the 13 on the end means 1.3 Gap , but I'm not 100% sure so dont quote me on thatCheers.Russ.
jimbobhtute Offline
#22 Posted : Tuesday, 31 January 2006 4:34:30 PM(UTC)
jimbobhtute
Hello to all, I have noticed that my Battery has gone flat, after leaving the car for a couple of days. I suspect it's the new setup with the Elec ignition but don't understand why... The instructions were followed as on the back of the packaging, so
1970 Green HT UTE...
jimbobhtute Offline
#23 Posted : Wednesday, 1 February 2006 3:47:40 AM(UTC)
jimbobhtute
Anybody???
1970 HT UTE
#24 Posted : Wednesday, 1 February 2006 5:18:12 AM(UTC)
Hi James,
Put an ammeter inbetween your positive battery terminal and your positive battery lead. If it reads more than 1 amp draw, you have a problem with something in your wiring.
Disconnect your ignition relay and see if the power drain falls. If
jimbobhtute Offline
#25 Posted : Wednesday, 1 February 2006 6:34:12 AM(UTC)
jimbobhtute
thanks dave, i'll give it a look over
1970 HT UTE
RussVRute Offline
#26 Posted : Wednesday, 1 February 2006 9:20:46 AM(UTC)
RussVRute
G'day James,
Check that thew new relay has the pins numbered in the same way as the old one, as this is the problem I had(as discussed earlier in this thread) I realise you probably already checked that and that your probably not dumb, but I thought I wo
jimbobhtute Offline
#27 Posted : Wednesday, 1 February 2006 4:19:13 PM(UTC)
jimbobhtute
Cheers Russ, I think I have it the right way, I followed all directions on the back including the wiring diagram.. Might have to bypass the ignition wire from the key, instead of relay..
james..
1970 HT UTE
2 Pages<12
