#1 Posted : Tuesday, 24 January 2006 4:41:56 AM(UTC)
Hi folks,
i have an xf on dual fuel but want to set the timing and plugs for lpg so i can get the best exonomy from gas.
Does anyone know what the timing and plug gap should be for lpg - in browsing the web it appears that it the timing should be advance a number of degrees - i just cannot find out what it should be.
cheersw
#2 Posted : Tuesday, 24 January 2006 8:28:49 AM(UTC)
Hi
The spark plug gap is ok at fac setting 1.1mm but if you use gas most of the time it would pay to go 1 heat range colder on plugs,
with timing you can advance up 2-3deg base timing from factory settings but you will have too much total advance it wo
#3 Posted : Wednesday, 25 January 2006 7:55:30 AM(UTC)
thanks Steve,
I'll advance the timing in incements of 1 degree and see how the perfromance and economy fair.
