Can anybody tell me if a power steering pump of a VH comodor with rack and pinion steering , the one that is mounted right down the bottom r/h side of of 202 motor, run a power steering box in a hj ute.
Hi Bob.
Yes, the low mount 202 VH P/Steer pump will do the job but you will have to get a custom made hose to suit.
Dr Terry. |
Yes the hoses should be long enough because I had to put that pump in the ute when I put the black motor in. The little plastic oil reservoir sits inbetween the radiator and the battery and the lines run under the balancer on mine. But it does fit.
If a man say's something in the woods and there is no women around, is he still wrong? |
Thanks for your advise about this.
