edmundo Offline
#1 Posted : Sunday, 28 January 2007 11:41:29 PM(UTC)
edmundo
hi
my hx tonner leaks ater when i give it a bath. it leaks at the pedals, and behind glove box. any clues??
trubluhq Offline
#2 Posted : Monday, 29 January 2007 1:21:15 AM(UTC)
trubluhq
oooh....two things come to mind.
(1) you may have multiple leaks (rust) in the air plenum in front of the windscreen
OR
(2) the two plenum drain pipes have decomposed, lose or blocked. They can be found at the LHS & RHS footwell (often white in colou
edmundo Offline
#3 Posted : Monday, 29 January 2007 3:19:48 AM(UTC)
edmundo
hey john,
they were blocked, clened them out, thanks heaps
ed
Munromad2004 Offline
#4 Posted : Monday, 29 January 2007 4:32:24 AM(UTC)
Munromad2004
Umm, even if they were blocked it still shouldn't let water inside the vehicle
Have you given it a hosing to see if it still leaks?
I'd be guessing that because they were blocked, water has been sitting in the plenum area and has rusted it out.
keithholden Offline
#5 Posted : Wednesday, 31 January 2007 4:11:09 AM(UTC)
keithholden
A fix for this is to take the grill off in front of window and cut all the fins out and weld flat steel in there in stead of finns to stop water going down there in the first place on the bad side the heater wont work to well as it will have to drag air u
