#1 Posted : Monday, 29 January 2007 12:28:34 AM(UTC)
hi i have a xm falcon and want to change it from 4 stud to 5 stud whats the best way
are you going ford or backwards
Bossy Offline
#2 Posted : Monday, 29 January 2007 1:47:15 AM(UTC)
Bossy
XW hubs and diff go straight in. Have fitted them to my XP.
#3 Posted : Monday, 29 January 2007 6:06:55 AM(UTC)
thanks for that bossy
#4 Posted : Thursday, 1 March 2007 10:29:43 PM(UTC)
XW diff is too wide, it would need to be shortened, use XR-XF stub axles, brakes etc up front. You will need adapter sleeves.
#5 Posted : Thursday, 1 March 2007 10:38:14 PM(UTC)
agree with Bob, XR-XF front stub axles and brake setup can be bolted to the original control arms and ball joints. You will need adappter sleeves to suit, I can help out on them. The XW diff should be too wide, did you shorten it Bossy ?
