#1 Posted : Friday, 27 January 2006 3:36:24 AM(UTC)
I have an EB Falcon and its fuel gauge suddenly started to go over full then drops down to empty. Temp gauge is fine. We have a Haynes manual that gives basic info, but we need to know if it is likely to be the float in the tank or the fuel gauge sender unit. Something with pictures that actually show where it is would help too. The back window leaked and sent water into the boot so thought that could have affected it but we found it quite dry even though the area is dusty and tape etc old and gummy. Last question: Is there likely to be a specialist in gauges in Perth? Many thanks ...
<i><b>Cal</i></b>
#2 Posted : Friday, 27 January 2006 4:18:28 AM(UTC)
hI
Sounds like fuel gauge sender,it is located in tank on lh side
of boot floor if you lift boot mat there is a round plate with about 6 phillips screws in it,remove this and you will see top of sender/pump assembly,you will have to undo a hose clamp th
#3 Posted : Friday, 27 January 2006 4:27:20 AM(UTC)
Thanks Steve. We knew about the round plate and my husband undid it. We just want to know how to find out what is wrong with it. There's a few wires with a white clip part way down and it all comes together with another clip. What do you mean "if it aint
#4 Posted : Friday, 27 January 2006 7:19:00 AM(UTC)
that's just my favorite saying at work!!!
the unit is in the tank that you need to check,when you get unit out you will need to check the resistance,with the wires 1 plug is for fuel sender and the other is for fuel pump.
if it ain't broke we can impr
