#1 Posted : Wednesday, 28 July 2004 12:46:04 AM(UTC)
Does anyone know how to identify a Hj Kingswood Sandman Utility--I think I may have one, but can't be sure? Any help at all much appreciated.
#2 Posted : Wednesday, 28 July 2004 2:54:48 AM(UTC)
I am 99% sure that they did not offer the sandman package on a Kingswood ute, Belmont only.
But tyhe only way to identify a sandman is by the compliance pate with the GVM or on the Body plate of Brisbane built cars.
See the sandman site for a
#3 Posted : Wednesday, 28 July 2004 3:12:18 AM(UTC)
#4 Posted : Wednesday, 28 July 2004 6:31:08 AM(UTC)
I've been told the same many times as well Warren. However i've got a set of HX Kingswood panelvan Sandman ID tags, that I pulled off a really low kM van back in the early 80's (<10,000kM). It was a 308 TH400, 2-seater with a 2200kg GVM. The thing I al
#5 Posted : Wednesday, 28 July 2004 6:32:35 AM(UTC)
#6 Posted : Wednesday, 28 July 2004 9:35:16 AM(UTC)
Byron
Do these tags have an XX7 stamped on the body ID plate? Being an Adelaide car (or sydney) they should not. I would suspect that these plates are off an optioned up kingo van as kingos could be optioned with 2 seats. (Belmonts could not from my know
#7 Posted : Wednesday, 28 July 2004 5:44:13 PM(UTC)
that seems correct fellas , I have a set of plates from a HZ sandman ute which I owned (it was rolled)and the GVW is 1950 , mine was an Adelaide car HZ8WM80 , 419051-A ,1926-18V with paint 30517 it was a 308 4spd with GV4
#8 Posted : Wednesday, 28 July 2004 7:16:14 PM(UTC)
I also have a set of HJ 308 M21 Sandman ID plates. It has a GVM of 1950kg. The HX was fair dinkum decked out fully as a Sandman, with original stripes, full length hoodlining, GTS dash, GTS wheels, buckets etc. The van was only lightly front smashed and w
#9 Posted : Friday, 30 July 2004 5:37:01 AM(UTC)
Holden made sandman utes and vans sixes & eights. It was not a kingswood or belmont it was a sandman. Check your tyre placard on the g-box if it was made with sedan type tyers vs commercial type it was a sandy
#10 Posted : Friday, 30 July 2004 5:54:53 AM(UTC)
I think I have given up on my quest to identify non Brisbane plant sandmans. Its just too hard. The only new info I have found is that there were different sticker combinations between the states. By that I mean similar colours but in different order or 2
#11 Posted : Friday, 30 July 2004 6:08:16 PM(UTC)
Sandmans are a belmont body. The Body ID for a sandman will be: HZ8WM70 (Belmont) not build in brisy or HZ8WM70 XX7 if built in brisy (Belmont with sports rims and sandman/GTS tyre pack) or HZ8WM70 XU3 if built in brisy with sports rims and commercial tyr
#12 Posted : Friday, 30 July 2004 8:06:49 PM(UTC)
That isn't true. The Sandman was not a separate model as far as the ID plates are concerned.
#13 Posted : Saturday, 31 July 2004 7:17:16 PM(UTC)
In the HZ sandman ute I had , where the roof lining stopped on the pillar near the back window , there was another piece of black vynil that went to the floor and across the the back tucked under the window rubber , in the corners of this was a metal stri
#14 Posted : Saturday, 31 July 2004 10:11:51 PM(UTC)
Hi Guys.
The amount of available factory info on early Sandmans is not great.
I tend to agree with Warren here, in that I have never seen a Kingswood Sandman in the flesh.
However, the HQ Sandman brochure shows a Sandman van with Belmont
#15 Posted : Wednesday, 26 January 2005 2:22:11 AM(UTC)
Hi,I was scanning through the sandman web pages and came accross
your comments,I actually have a
HJ Kingswood sandman ute.All sandman features stripes as well
but plated Kingswood and I bought
it as a genuine old buggy,car is
half way through a resto
