#1 Posted : Tuesday, 7 February 2006 4:22:15 AM(UTC)
Hi
Not my usual forum because i have an MGB. Very modified 4 cyl race car and i've just found out that the car is fitted with a shortened ford axle with a 9" diff. Not sure what it is out of though. The ratio must be low cause top speed is only approx 170km/h, about a 4.3. My problem is i need a new centre ratio of about 3.9, cause at Phillip Island i'm at top speed at the start of the straight! But as said I don't know about the axle. Are there many differeces between different ford axle fot the diff houseing? Any help would be great.
Adam
#2 Posted : Tuesday, 7 February 2006 7:54:24 AM(UTC)
With the 9 inch diff housings there are literally dozens of different housings,in america they were in f trucks and cars for many years and these housings are everywhere in australia,they come in all different widths and mounts,the australian housings wer
#3 Posted : Tuesday, 7 February 2006 9:40:20 AM(UTC)
9 inch also came with 28 and 31 spline axles. The diffs also came with limited slip, detroit locker or open wheeler. As vzgen3 said, there are heaps of different centres available. Best bet would be to see exactly what your diff has had done to it. As
#4 Posted : Tuesday, 7 February 2006 11:24:55 PM(UTC)
Contact this mob. http://www.quickperformance.com/index.htm
They used to have a really good write up describing virtually every difference with 9" rear ends but they appear to have removed it from their web site. Maybe they could email it to you. http
#5 Posted : Tuesday, 7 March 2006 7:53:55 PM(UTC)
The nine inch identification page that I mentioned earlier is now at:
http://www.kevinstang.com/Ninecase.htm
