#1 Posted : Thursday, 9 February 2006 6:06:30 AM(UTC)
hi ford fans dont know alot about fords.Ihave an A model Rod chassis set up for a windsor/c4.Does anXB 351 cleveland auto bolt up the same as Ive seen a lot of old fords that had windsors now have clevelands.My engine mounts measure 440mm.Anther option I was considering was a windsor efi out of an eb or later ford.If the engine fitted that would be great but Im expecting the auto crossmember to bemoved further back.And finally would xc axles fit an xb diff.Ta for any advice
XB351 Offline
#2 Posted : Thursday, 9 February 2006 7:42:25 AM(UTC)
XB351
Windsors and cleveland do use the same mounts. The EFI engine should also mount up.
XC axles should fit an XB diff without any issues.
