#1 Posted : Monday, 13 February 2006 8:02:54 AM(UTC)
where do you buy engine mounts for a precross flow 250 into a xp
keith
#2 Posted : Wednesday, 15 February 2006 8:18:59 AM(UTC)
Try the castlemain rod shop(rod hadfied) they should be able to help you
if it ain't broke we can improve it.
Cheers Steve
#3 Posted : Wednesday, 15 February 2006 6:54:02 PM(UTC)
parts like that go through ebay from time to time
#4 Posted : Thursday, 16 February 2006 7:56:14 AM(UTC)
i have found some thank you for your input .rod shop no good 6cy mustang are the same most of the mustang imports have them as they in stall v8
keith
#5 Posted : Thursday, 10 August 2006 6:55:27 AM(UTC)
You can use the 170 engine mounts to fit a 250 into an XP all you need is to move the mounts outwards and you have to make a gearbox mount I have put a 250 2V with a C4 auto into an XP
#6 Posted : Wednesday, 6 September 2006 9:23:30 PM(UTC)
#7 Posted : Thursday, 7 September 2006 5:15:25 AM(UTC)
I didnt have any trouble with the sway bar as I didnt have to remove it
The sump is a tight fit but it fits ok
Make sure that you use the right sump
