Munromad2004 Offline
#1 Posted : Wednesday, 15 February 2006 2:50:25 AM(UTC)
Munromad2004
A friend is looking at buying a Torana that is advertised as an XU-1
Can anyone help with the ID of this vehicle.
Tag says 8D11PCL237965J
Chassis Number is BLJ2219A
I hope these are correct as his writing is hard to decipher.
regards
Darren
#2 Posted : Wednesday, 15 February 2006 3:32:04 AM(UTC)
contact the sydney xu1 club they have the microfish data from GMH on all XU1 models
#3 Posted : Wednesday, 15 February 2006 3:42:31 AM(UTC)
This is from AMC :8-holden ,D-GTR, 11-2door, P-engine code -(3300X)XU1, C -model year-1973(10/72-8/73),L2-Adelaide built,prod #37965, J-model series.
chassis number depicts LJ model built in Adelaide.
#4 Posted : Wednesday, 15 February 2006 6:23:07 AM(UTC)
Munromad2004
Thanks guys. I was at work and access to many sites is blocked. Luckily Fastlane sneaks through the system.
I did a google search and ended up with some info from the Canberra Torana Club that showed 8D11 as applicable to both GTS and XU-1.
That's
#5 Posted : Wednesday, 15 February 2006 6:38:21 AM(UTC)
Being a 1973 model, the P after the 8D11 gives it away as an XU-1. If it was just a GTR it would read 8D11L. HOWEVER, check it out carefully before shelling out good money. Lots of these have been rebodied, have mismatching plates etc.
#6 Posted : Wednesday, 15 February 2006 12:07:53 PM(UTC)
Just a slight correction...XU1's have 17 gallon (77 litre) fuel tanks...
Cheers...Dave
#7 Posted : Thursday, 16 February 2006 9:44:25 AM(UTC)
Look at the battery tray. its alot smaller than standard to clear the carbie. look under the guard aswell to see if the brace from the brake booster to the inner guard hasnt been moved. XU-1 has the bigger booster. Chrome strips at the top of the door and
#8 Posted : Friday, 17 February 2006 2:05:15 AM(UTC)
Munromad2004
He has now had the car checked out by the Sydney? XU-1 club and all verified as genuine.
If any guys from the club get on here, please know that he was absolutely delighted with the helpfullnes of the club members and greatly appreciated your advice.
