#1 Posted : Saturday, 18 February 2006 8:49:26 AM(UTC)
I am chasing the measurement on a V8 M20/21 from the front of the bellhousing face (where it contacts the block) to the center of the shifter. The reason for this is I want to fit a T5 from a VN into a HZ Tonner and I want to relocate the T5 shifter to be in the same position as the M20/21 so that it will go through the original floor hole and factory console hole. I do not wish to cut the floor or reposition the console further back to suit the T5s original shifter position. Would anyone know if this is possible using extension housings off other T5s available, eg 6 cyl EF/L Falcon ?? or is there some modifacation that can be preformed to the original box's shifter that will achieve what I am after?? Has anyone done this mod to a T5?? Would appreciate any positive accurate feedback. Cheers TD
#2 Posted : Wednesday, 22 February 2006 2:31:32 AM(UTC)
Hello Twodogs,
Can't help you with the shifter position of the four speed but I have just climbed under my EB Falcon & measured the T5 in it to be roughly 720mm from bellhousing face to shifter stick
I think that this measurement would be way sho
Edited by user Wednesday, 22 February 2006 2:34:47 AM(UTC)  | Reason: Not specified
#3 Posted : Saturday, 25 February 2006 1:11:00 AM(UTC)
Boy howdy Two Dogs are you in luck, I done the VN 5 litre T5 mod into a WB ute in 1995, and learnt the hard way. If your adament about not cuting the orignial thansmition hole , I persume because you don"t want to plate that body rib in the flour pan, the
#4 Posted : Sunday, 26 February 2006 11:00:39 AM(UTC)
If you would like to send an e-mail my address is sharlees@tpg dot com dot au. I could give you my phone number there but I very rarely answer the phone in case it is the Mother-in-law,ooohh a cold shiver just went down my spine very creepy. Cheers TD
#5 Posted : Friday, 3 March 2006 11:57:29 PM(UTC)
Haven't heard from you yet?, I sent a e mail to you address starting to explain the options and as I mentioned there is a lot of factors to consider in the mood.will be home all weekend working on the Holdens so call if you want the good oil. By the way i
