wimjack Offline
#1 Posted : Monday, 20 February 2006 12:22:23 AM(UTC)
wimjack
HI
I have fitted a set of AU thermo fans to my XB falcon and thought Ill get the job done properly so I got an Auto electrician in to wire them up.He fitted a Davies Craig thermo switch and wired it up straight to my battery.The trouble I have is that when I park my car for a short while and try to start it the fans are drawing all the power from the battery so the car wont start.Not Happy!
Can any one tell me the correct way to wire them up?
Thanks Jack
jack
XB351 Offline
#2 Posted : Monday, 20 February 2006 5:44:08 AM(UTC)
XB351
Did your useless sounding auto elec fit a relay? If he did? Run the trigger wire to the accessories.
The relay should have four or five pins :
1 = earth
2 = power in
3 = power out
4 = trigger
If you do it that way? The fans can only come on i
wimjack Offline
#3 Posted : Sunday, 26 February 2006 3:55:29 AM(UTC)
wimjack
Yes he did run a relay,He did do something right. Any idea which accessorie wire I should tap into on an xb falcon.
Thanks Jack
This is Ford Country
#4 Posted : Sunday, 26 February 2006 5:06:33 AM(UTC)
Do you have a test light or multimeter? Just find a wire that is powered when the ignition is in the On AND the Accessories position and tap into that (using solder and preferrably shrinkwrap too).
As this wire is only being used to power the relay, it
This page was generated in 0.146 seconds.
