308hjute Offline
#1 Posted : Tuesday, 6 February 2007 8:21:41 AM(UTC)
308hjute
Does anyone have one they could scan and send to me? Please?
Am interested in the difference between WB and H series in relation to the blinker stalk. I want to put a WB stalk into my HZ tonner and have the hazard lights work........
Kev
#2 Posted : Tuesday, 6 February 2007 8:32:00 AM(UTC)
Hi Kev,
The colour coding for the wiring is mostly the same in HZ and WB. I did the WB Stato dash into HQ trick and there was a small variation (which I now can't remember) for the wiper motor but it was easily solved.
As the HZ used the rear indica
Edited by user Tuesday, 6 February 2007 8:33:42 AM(UTC)  | Reason: Not specified
308hjute Offline
#3 Posted : Tuesday, 6 February 2007 8:44:10 AM(UTC)
308hjute
Qute,
Thanks for that. Probably should have included a bit more info. The tail lights I have on the tonner have separate reverse lights. I have simply run the feed to these straight from the switch (column shift at the moment).
I have an early Co
#4 Posted : Tuesday, 6 February 2007 9:15:24 AM(UTC)
Pretty close Kev.
I forgot to say that the colour coding on the wires is the same but the ORDER of the wires is different between HQ and WB (not 100% sure about HZ) at the column loom to main loom plug.
The HQ has 2 wires feeding the indicators (one
Edited by user Tuesday, 6 February 2007 9:17:47 AM(UTC)  | Reason: Not specified
This page was generated in 0.138 seconds.
