Siggs Offline
#1 Posted : Thursday, 23 February 2006 8:10:29 AM(UTC)
Siggs
Hi guys,
I am currently fitting an M20 into my Hr, box and crossmember mounted o.k. but I have run into trouble finding a slave cylinder to suit the bell housing I am using, the cylinder bolts to side of bell housing, looks like body of cylinder should be broad and bolt holes staggered, can anyone give me an idea which cylinder I need ?
#2 Posted : Thursday, 23 February 2006 7:24:03 PM(UTC)
Hi Siggs.
The slave cylinder you need is an FE to EK Holden one, including the matching pushrod. You will then need a Dellow adaptor bracket, & it should come with the correct bolts.
Dr Terry.
Siggs Offline
#3 Posted : Friday, 24 February 2006 8:10:20 AM(UTC)
Siggs
Thanks for the response, maybbe I should have mentioned my HR originally had crash box fitted so I have had to fit a late model hydraulic clutch bell housing, not sure what model it's out of though. Is the slave cyl and adaptor you're talkibg about still
Siggs Offline
#4 Posted : Sunday, 26 February 2006 7:58:59 AM(UTC)
Siggs
Disregard previous post !, Its amazing what you can find when you have half an idea what you are looking for !.... got bracket today at local wreckers, all I need now is speedo cable & get tailshaft sorted....Just hanging out to get the old girl back on t
#5 Posted : Wednesday, 1 March 2006 7:48:43 AM(UTC)
hr auto tailshaft and speedo cable will fit
Siggs Offline
#6 Posted : Thursday, 2 March 2006 5:17:45 AM(UTC)
Siggs
Thanks, had been told that but they're a bit hard to come by down here in Tas !, think I may just have to get the original cut 'n shut
