#1 Posted : Sunday, 5 March 2006 9:50:33 AM(UTC)
Hi I would like to know if there is any difference with the control arms on the RTS frontends on the HZ-WB compared to the non RTS frontends on the HQ-HX and if there is what would happen if you fitted non RTS control arms to a RTS frontend.Cheers TD
#2 Posted : Sunday, 5 March 2006 11:00:05 PM(UTC)
They are basically identical. The HZ/WB lower arms normally have a bigger hole in the bottom so that a larger shock can fit through but that is about it. RTS was achieved in the upper control arm mount on the chassis. It is the A9X/UC where RTS was achiev
#3 Posted : Tuesday, 7 March 2006 9:05:21 AM(UTC)
Appreciate the reply. I started to get worried when I keep seeing NOS control arms selling on e-Bay and they are listed as HZ-WB. My Tonner project has been assembled from the nuts and bolts and parts from at least 40 different HJ-WB part donor cars so I
