Hello all, Need some advice on tuning a single barrel Stromberg with the adjustable main jet. I don't know what order to tune the damn thing, Do I adjust the mixture first or the Jet??? Now I know that the basic setting for the mixture screw is 2/5 turns out, but I can't seem to find the right mix on the jet side. The car either gets bogged down low, like on take off, or around the 2500-3000 RPM range when holding revs it starts to spit and cough.. Is the tuning of the jet an exact science??? Cheers james.. 1970 HT UTE Edited by user Monday, 6 March 2006 3:59:38 AM(UTC)
| Reason: Not specified |
1970 Green HT UTE... |
Hi jimbobute.
These adjustable main jets are a pain in the **se. The main jet, mainly controls the fuel mixture at wide open throttle. This is really only properly achieved on a dyno.
The other screw you are referring to is the IDLE mixture screw it |
I dunno. I had one in my EH, it worked pretty good. Although my father was handy at tuning.Actually reminds me I have a brand new one in my spare parts box that i never got around to fitting. Should put it on ebay and see what happens.
Thanks guys, I'm not sure if I like the sound of burning my valves to adjust the tap, but thanks Dr Terry. Might change it out for fixed jets again..
cheers james
1970 HT UTE |
