#1 Posted : Monday, 6 March 2006 6:22:11 AM(UTC)
i have a hz ute and would like to fit wb tail lights but am having problems finding the reverse circuit as the hz had the reverse lights and the indicators connected to the same globe and the wb had a seperate globe for reverse, i was wondering where the reverse switch was whether it was on the box or is it on the column any suggestions would be greatly appreciated
thanx heaps jimmy
6pak Offline
#2 Posted : Tuesday, 7 March 2006 8:12:41 AM(UTC)
6pak
Hi, You're in the wrong forum for this question but i'll throw in my two cents worth anyway as i changed tail lights on my old HJ Sandman over to WB units in the 80's. The switch will be on the gearbox/transmission. Get hold of a Gregorys manual or simi
#3 Posted : Tuesday, 4 April 2006 11:16:10 AM(UTC)
Actually the switch is on the lower part of the steering column just above the floor, on the top part of the column.I did this conversion with the tonner as the reverse and trafficator lights are the same and I wanted separate ones. There is a connector p
les Offline
#4 Posted : Wednesday, 5 April 2006 6:24:51 AM(UTC)
les
It’s good to see Ford guys helping Holden guys and Holden guys reading the Ford forum, that’s what it’s all about.
Ford rules and when they don't Holden do (they are both GREAT CARS)
