#1 Posted : Monday, 6 March 2006 6:27:39 AM(UTC)
where do i find the reverse switch in a hz ute with a 3 speed auto as i am trying to fit wb taillights, what is the easiest way to wire these lights up any suggestions appreciated
#2 Posted : Monday, 6 March 2006 6:57:02 PM(UTC)
When in reverse your blinkers should light up as reverse lights. find them wires and disconnect them. hook them up to the clear lights of your WB lights. that all my auto sparkie has done. i feel silly that i got him to do it being so easy.
#3 Posted : Monday, 6 March 2006 8:11:45 PM(UTC)
Hi rumman69.
The reverse light switch in an HZ auto is at the base of the column, if it's a column shift, it's part of the inhibitor switch.
Using a test light light, switch the ignition on & see which terminal lights up when reverse is selected. I
#4 Posted : Thursday, 9 March 2006 3:45:30 AM(UTC)
thanx heaps for the advice i managed to find the reverse switch and connect some new wires and now reverse seperate from the indicators
thanx heaps the rumman69
