Blue ballz Offline
#1 Posted : Monday, 12 February 2007 7:37:14 AM(UTC)
Blue ballz
Having trouble with lights on vs s2 ute. Put new globes in for more light not all that noticeable and now blown fuses. Any ideas
#2 Posted : Tuesday, 13 February 2007 11:06:30 AM(UTC)
New globes I assume you fitted more powerful headlight ones. If too much more powerful could be drawing too much current causing fuse problem. DO NOT fit higher capacity fuses you risk a bonfire. check all the earths a bad earth can cause poor lighting. E
Blue ballz Offline
#3 Posted : Wednesday, 14 February 2007 6:56:27 AM(UTC)
Blue ballz
yeh fitted globes that gave a 50% more light just picked them up at super cheap
Blue ballz Offline
#4 Posted : Wednesday, 14 February 2007 6:57:31 AM(UTC)
Blue ballz
where abouts should i be checking for the leakages
#5 Posted : Wednesday, 14 February 2007 8:59:47 AM(UTC)
First thing you need to know is do they use 50% more watts. If so you are running probably over the ragged limit for your wiring harness, remember Holden and all other car manufacturers only build in wiring to the designed current load, not like in the ol
