Duzty Offline
#1 Posted : Thursday, 9 March 2006 8:26:43 AM(UTC)
Duzty
approx. how much would it cost to build an engine/driveline like this:
Fully worked 350 Chev, 400 hp, Turbo 350 trans.
Hand finished port & polished heads with big valves, intake & exhaust matched ported, victor junior manifold with 750 double pump holley, tuned length 1 3/4" pacemaker extractors with twin 2.5" exhaust finishing with droppers at diff, fully balanced with 11:1 pistons, specially ground cam to suit eng & d/train performance, hyd lifters, roller rockers with screw in studs, scorcher electronic distributor, 2000rpm stall converter, std T bar shifter, lge built drive shaft, 9" diffshortened to suit , 3.55 gears, w/grain GTS dash.
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop online directly from Rare Spares Perth go to https://rsp-secure.com/r...pares/?referrer=fastlane
CherryBomb Offline
#2 Posted : Thursday, 9 March 2006 8:09:20 PM(UTC)
CherryBomb
Hi Duzty,
It will depend on if the Build will be done by your self, Or by an engine builder, And what parts you or they used and lastly the combination?
"Fully Worked" is a Hazy term- you could have a 1000HP sbc if you had the money.
So its approx
Never stop being inspired,
#3 Posted : Thursday, 9 March 2006 9:20:55 PM(UTC)
as fair as i know you can run 11:1 comp on BP ultimate and that 98% octane
zac
Nothing beats cubic inches !!!
#4 Posted : Friday, 10 March 2006 12:58:13 AM(UTC)
Theres a whole heap of questions that need to be answere before you get a price.
but a few points.
1.) 11:1 is do-able with alloy heads and a big cam and 98 octane. You wont be able to run comp this high with a smaller cam and/or cast heads. Reali
#5 Posted : Friday, 10 March 2006 9:34:27 AM(UTC)
You are around the corner from Brian Sadler at Performance Modifications he is one of the better engine builders. Go and talk to him
Duzty Offline
#6 Posted : Friday, 10 March 2006 11:55:43 AM(UTC)
Duzty
im not building it, im looking at a HJ prem with it in. he is telling me its $9000 worth of engine and claims he built it himself (which i dont beleive as it has NSW rego, and he lives in a country town in WA). i personally dont know much about working en
#7 Posted : Friday, 10 March 2006 10:38:04 PM(UTC)
to be fair mate. 9k for a 400HP 350 chev is not that out of the ordinary. it all adds up very quickly and if it was done properly, there could be $1000 in machining/balancing alone.
Hand porting and polishing is exxy as well - even if its done incorrec
Duzty Offline
#8 Posted : Saturday, 11 March 2006 1:59:40 PM(UTC)
Duzty
but its a HJ prem. not coupe.
Edited by user Saturday, 11 March 2006 2:08:18 PM(UTC)  | Reason: Not specified
#9 Posted : Saturday, 11 March 2006 10:29:17 PM(UTC)
The stall should be at least 2200-2300.
The rego means it is going to have to go over the pits which should be a breeze from your description.
If it doesn't feel right don't buy it. rely on your intuition,
Otherwise offer $10,000, if you are happy with
CherryBomb Offline
#10 Posted : Sunday, 12 March 2006 12:17:16 AM(UTC)
CherryBomb
Go for a Drive, If the Thing pushes you back into the seat and gives you whip lash, than yeah, 400 Neddies would be close LOL
But No really. If the Power figure is questionable, And the Dude built it himself. Then He'd have NO Prob giving you an extens
#11 Posted : Tuesday, 14 March 2006 1:02:01 AM(UTC)
Dutzy - I know its a prem - it says so in your post.
14k for a micky mouse prem with a 400hp 350 chev sounds reasonable. He will be negotiable!!!
the equivalent in a 2 door would go for 20k +
If you dont want to pay it...then dont.
But basic
