I have bought a set of HX LE honeycombs to put on the tonner, but they need a bit of a paint, I havent decided yet whether to paint them in the original colour, or paint them white to match the tonner, either way, I have no idea what type of paint is best, and if I decide on the Gold, can anyone tell me the colour code? Any help appreciated,thanks.Russ.
Hi Russ, I did have some info somewhere on colour for the rims back from when I had my LE. I will try and dig it up for you. But have a look around, I wanted a mix of colours for my road bike and found some nice work using candies. If your not after the o
gold met....shade number 203-17989 life's to short not to be.... Edited by user Friday, 10 March 2006 8:08:08 AM(UTC)
| Reason: Not specified
Thanks for that retro, but what type of paint is best for this application (enamel, acrylic 2-pack etc,) and how do I remove the old paint without damaging the alloy? any help appreciate.Cheers.Russ.
Yours should have the polycast over the alloy frame. They should be spongy to feel, or are they just straight alloy? you can get both types. I never had to do mine so I don't know how you will go removing the paint without damage to the polycast. Will loo
Hi Guys.
Polycast wheels do not contain any alloy.
AFAIK the wheels are a steel pressing with the 'polycast' plastic centre, moulded into it. The polycast plastic is flexible & is more like a permanent hubcap. You will have to experiment with variou |
contact a plastics factory or panel shop
I've used that polyeurethane (sp?) wheel paint on a few alloy bike frames. It's pretty tough if you prep the suraface with some 240 grit wet dry, clean it down with wax and grease spirit and spray on a few coats. Let the base coat get touch dry, then buil
Hi,
Hx Le honecombs, were they hard to find & how much would you be expected to pay for a set ?
Rusty B
