#1 Posted : Monday, 13 March 2006 9:38:32 AM(UTC)
Can you tell a factory 302 or 351 just from the engine number# ?
If someone can tell me all the revelant codes it would be much appreciated.
Regards, Peter
XB351 Offline
#2 Posted : Monday, 13 March 2006 9:51:16 PM(UTC)
XB351
nope.
XB351 Offline
#3 Posted : Monday, 13 March 2006 9:51:41 PM(UTC)
XB351
You need to measure the stroke.
#4 Posted : Saturday, 25 March 2006 7:51:41 AM(UTC)
what about fireing oder they diferent
Paul351xb Offline
#5 Posted : Sunday, 26 March 2006 5:41:46 AM(UTC)
Paul351xb
firing order for a clevo 302 and 351 are the same. Unless the engine is still in the car with the original compliance plates it's a case of taking out the spark plug and bending a coat hanger when the wife isn't looking.
#6 Posted : Sunday, 16 April 2006 4:16:07 AM(UTC)
drop the sump and read the crank if you can't figure it from the coat hanger trick...The engine size is cast on the crank. This will give you a definate answer
