DaMiEn Offline
#1 Posted : Wednesday, 15 March 2006 5:42:29 AM(UTC)
DaMiEn
hey guys can u plz tell me the easyest wa to romove a engin because i have heard that its easyest to romove wen the gearbox is out wih it and others say its just as easy to take it out with out the gear box
CherryBomb Offline
#2 Posted : Wednesday, 15 March 2006 5:49:44 AM(UTC)
CherryBomb
If its an 8 you'll find you'll need a little more muscle to hold the trans/ Box away from the Fire wall as you lift the two out!.... Hard if your a runt. Not so if your Burly. :)
6s are generally the same deal. Just lighter. And you have a little more
Edited by user Wednesday, 15 March 2006 5:57:17 AM(UTC)  | Reason: Not specified
Never stop being inspired,
DaMiEn Offline
#3 Posted : Wednesday, 15 March 2006 6:02:47 AM(UTC)
DaMiEn
thanx its only a 186 soo i think i juss tak out da box aswell
classic oz wreck Offline
#4 Posted : Wednesday, 15 March 2006 7:43:01 AM(UTC)
classic oz wreck
damien,when you come in to pick up the motor ill show you what to do...
www.classicozwreck.com.au
#5 Posted : Wednesday, 15 March 2006 8:29:55 AM(UTC)
I've always found it easier to remove an 8 than a 6, simply because they are shorter which means more space between the motor and radiator support panel.
As Kustom says it's all a good learning experience, but how much time do you have and how much do yo
#6 Posted : Wednesday, 15 March 2006 10:17:29 PM(UTC)
There are a couple of ways to remove engine. If your car is a HK,T,G then they are easy to get out with the box as you can remove the bonnet slam panel & wheel the whole lot forward through the radiator hole. I believ that you can do this on any full size
