tanart Offline
#1 Posted : Wednesday, 14 February 2007 9:38:16 PM(UTC)
tanart
I have just bought myself a 2 owner HQ GTS 4 door. I have most the car i all original and all complete. I have been given another motor and need to know whether or not its the original motor and whether or not the fron railings have been changed.
Model: HQ80469
Body: 400061M
Trim: 1865-30x
Paint: 567-15332
8Q69RDJ400061Q
Other tag: CHQ04494M
Details of motor 1: QR420964 (original engine)
details of motor 2: QR630050
Railings ID number: DHQ00219M
gts082 Offline
#2 Posted : Wednesday, 14 February 2007 10:05:34 PM(UTC)
gts082
should check the date on the block,3 stands for 1973 4 stands 1974,also should be other markings i think -a or b c which stands for the month of that year.what month/year model on the plates.
Rockett Offline
#3 Posted : Wednesday, 14 February 2007 11:08:44 PM(UTC)
Rockett
HQ engine numbers ended around the 550XXX so motor 2 would be a HJ-X.
Regards Rockett
Rockett Offline
#4 Posted : Wednesday, 14 February 2007 11:12:37 PM(UTC)
Rockett
Sorry forgot to add check the number on the chassis next to the steering box, against the tag number CHQ04494M they should match for an original chassis.
Regards Rockett
tanart Offline
#5 Posted : Wednesday, 14 February 2007 11:33:25 PM(UTC)
tanart
thanks for the info. i'll check the details tonight.
Munromad2004 Offline
#6 Posted : Thursday, 15 February 2007 4:52:26 AM(UTC)
Munromad2004
Grab the engine date casting details and post them up here.
It is a 3 or 4 digit alpha-numeric code cast on the top front of the block near the water pump.
This will tell you exactly what day that block was cast.
While you cant 100% verify it is
#7 Posted : Friday, 16 February 2007 12:45:41 AM(UTC)
Hi Guys.
If the chassis number (on the rail) is DHQ00219M and the chassis number on the ADR Compliance plate is CHQ04494M, then the chassis rails have most likely been changed. These 2 numbers should always be the same as each other.
Dr Terry.
