DaMiEn Offline
#1 Posted : Thursday, 16 March 2006 4:09:51 AM(UTC)
DaMiEn
hey guys juss a question i was wondering how a standard 186 runs on gas thats if any of u have one on gas ? i know some engind run like dogs on gas i was wondering if this is the case with a 186 ?
#2 Posted : Thursday, 16 March 2006 10:48:10 AM(UTC)
Damien
It depends on what you mean by running like a dog. If it is set up properly there is no reason why a 186 will not run smoothly and reliably on gas but don't expect it to have the same performance. You will loose about 12 to 15% of power on dua
#3 Posted : Saturday, 18 March 2006 12:47:10 PM(UTC)
hey brian, can you give me the same kind of advice but for a small block chev 350?could you tell me exactly what i need too do to change my 350 to straight gas and also duel fuel(havent decided what to go for yet).it would be greatly appreiciated.
#4 Posted : Saturday, 18 March 2006 7:38:58 PM(UTC)
I have 3 cars on Duel ,WB V8 , HX V8 and VS V6 all run well on both , as said before you can feel a slight power loss as duel setups are a compremise , I use my cars for work and you can`t beat the lower fuel cost of gas I used to spend about $150.per for
#5 Posted : Sunday, 19 March 2006 7:27:27 AM(UTC)
Grant
If your Chev is a pre unleaded with a points ignition then the same thing applies. Back in those days almost everyone ran dual fuel and just about every make of car just had a tank with a high pressure line to a solenoid controlled filter lock u
This page was generated in 0.170 seconds.
