#1 Posted : Thursday, 16 March 2006 9:52:09 PM(UTC)
Need to change them in the ute. It's a HX 6 cylinder, but i'm unsure of the diff. The previous owner said he replaced it with a salisbury type. Are the differential housings the same?
#2 Posted : Thursday, 16 March 2006 10:15:23 PM(UTC)
Hi Spud.
The type of diff doesn't matter, all HQ-WB rear axles use the same wheel bearings. The only difference is when you have rear discs there is an issue with a seal & spacer but the bearing still remains the same.
Dr Terry.
#3 Posted : Thursday, 16 March 2006 11:00:25 PM(UTC)
Thanks again Terry.
