RussVRute Offline
#1 Posted : Friday, 24 March 2006 7:09:31 PM(UTC)
RussVRute
G'day all,
The motor has stopped working on my fan and I was wondering if these can be easily re-wound or re-brushed etc. or am I better off buying a new one and are they still available, I see second hand ones occasionally on Ebay but cant be sure how long they will last as they are all about the same age as mine now.Any help appreciated.
Cheers.Russ.
ozjason Offline
#2 Posted : Friday, 24 March 2006 7:54:30 PM(UTC)
ozjason
What's actually wrong with the fan? Is it something obviously burnt out or did it just stop? Check that the resistor component hasn't overheated and burnt out - this is a safety thing to stop the wiring getting too hot when running on slower speeds...
#3 Posted : Friday, 24 March 2006 11:57:00 PM(UTC)
The red WA dirt was the extra cost Jason.... :-)
Russ, I agree with Jason. Have a look at the wiring and switch first. Then, if you have no joy there, pull the fan motor out and have a good look at it. You may find that it just needs new brushes.
I
ozjason Offline
#4 Posted : Saturday, 25 March 2006 1:47:15 AM(UTC)
ozjason
I've opened up a landscaping shop to get rid of it all - it's going by the truckload! :-)
Actually, since you're watching, Dave, I'm up to mounting the unit inside. Yeah, yeah, things move slowly around here when it's just a weekend job... I can put
#5 Posted : Saturday, 25 March 2006 7:12:17 AM(UTC)
Most HQ's had them mounted IN the glovebox....most other cars had them mounted in the middle of the dash except for my first LJ that had it mounted under the glovebox....That seems to cover all bases mate.
Personally, I reckon if you can mount it far e
trubluhq Offline
#6 Posted : Sunday, 26 March 2006 6:18:30 AM(UTC)
trubluhq
Russ...I think HX was same as HQ. It usually isnt the fan. Its the resistor pack.
Open bonnet look for 2 heater hoses at the heater box. Just to the right u will see a while electical connector going to a thing with 2 screws. that is the resistor. Take
RussVRute Offline
#7 Posted : Monday, 27 March 2006 8:02:59 AM(UTC)
RussVRute
Thanx Guys for the repies, but I fixed it, dont know what I did but I pulled it apart, checked that everything inside like the brushes, connections etc, everything seemed OK so I put it back together without actually doing anything to it and now it is wor
ozjason Offline
#8 Posted : Monday, 27 March 2006 7:12:24 PM(UTC)
ozjason
Good to hear, Russ. :-)
Jason.
