#1 Posted : Sunday, 26 March 2006 4:23:36 AM(UTC)
Any one who has done this swap please help, can I use Chev to Holden adapters same as Chev to HQ or not?
I have a set with off set of approx 20mm to one side.
Any other info would be great
Edited by user Sunday, 26 March 2006 4:33:05 AM(UTC)  | Reason: Not specified
#2 Posted : Sunday, 26 March 2006 8:17:55 AM(UTC)
You use stock chevy engine mounts. But you need special adaptors that bolt to your crossmember and mate with the chevy engine mounts. The genuine ones come up on ebay sometimes for around $100 a set. Or you can get aftermarket ones at a speed shop.
#3 Posted : Sunday, 26 March 2006 9:26:03 PM(UTC)
The HQ-WB ones are not the right ones for a HK-HG. You need as Paul says factory HK-HG 307/327/350 adapters with HK-HG mounts to suit the same.
For the TH350 you simply need a HT-HG V8 powerglide or Saginaw crossmember, speedo cable and tailshaft
#4 Posted : Monday, 27 March 2006 4:47:22 AM(UTC)
Thanks guys
#5 Posted : Wednesday, 19 April 2006 12:26:33 AM(UTC)
Castlemaine Rod Shop were very helpful & have supplied all the parts at a good price.
PAUL saw some adaptors on ebay went for over $300.00
Castlemaine $130.00. NZ Rare Spares $247.00
#6 Posted : Wednesday, 19 April 2006 8:36:29 PM(UTC)
You will also need a sump, these are different to the HQ/Chev sump.
Warren
#7 Posted : Monday, 24 April 2006 3:09:02 AM(UTC)
Thanks Warren ,I have correct sump & pickup.
Edited by user Monday, 24 April 2006 3:10:26 AM(UTC)  | Reason: Not specified
#8 Posted : Monday, 24 April 2006 3:16:26 AM(UTC)
Originally posted by Nos_VQ
You can pick up the adaptors quite cheap if you look around on ebay. I got a set for $60. Y
