lonemonaro Offline
#1 Posted : Sunday, 26 March 2006 6:34:45 AM(UTC)
lonemonaro
Hi guys,
I am attempting to remove the instrument cluster off my XC, but it appears that I have to first remove the headlight switch and how do you remove it ?
Does the headlight switch need to be removed or am I overlooking something.
Kind regards
George
#2 Posted : Sunday, 26 March 2006 8:25:46 AM(UTC)
First you have to remove the knob from it. To do this you need to reach up under the dash and on the side of the light switch housing there is a plastic "button" you have to press to be able to pull out the knob. Press this button while GENTLY pulling o
lonemonaro Offline
#3 Posted : Monday, 27 March 2006 10:49:11 PM(UTC)
lonemonaro
Thanks Nathan, as I knew that it had to be something.
Kind regards
George
lonemonaro Offline
#4 Posted : Sunday, 16 April 2006 8:22:25 AM(UTC)
lonemonaro
Hi Nathan,
I found the plastic button that you were talking about :)
It appeared as a small arch with a dimple at the top and from what also appears as a rubber seal around it.
In my haste and instead of pressing the button, I managed to break
