DOES ENYONE HAVE A COPY OF INSTALATION 4 A B AND M MEGER SHIFTER IF SO FAX NO WILL FOLLOW
Fax number? Have you got a printer? http://static.summitraci...ions/bmm-megashifter.pdf___________________ Why are you reading this, you should be looking up there^^ Joetech Tonner - coming soon! |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
Oh, and the TH-200 is the same as our trimatic for these instructions..
HTH void
Just look on the B&M site
