nick ht Offline
#1 Posted : Tuesday, 20 February 2007 7:37:56 AM(UTC)
nick ht
okay all help valued here
currently car is 6/4 speed manual however will become v8 308/turbo 350 auto floor shift
brakes are disk front drum rear no booster think i need to upgrade that ?
how about engine mounts ?
tailshaft willl change ?
suspension?
#2 Posted : Tuesday, 20 February 2007 7:48:07 AM(UTC)
You'll probably need to fit a booster. Easy job.
Engine mounts on the crossmember are the same.
I'd fit heavier front springs, but probably not absolutely necessary.
You really need to fit a bigger diff, but a V8 banjo should be your minimum (bigger un
kanks Offline
#3 Posted : Tuesday, 20 February 2007 7:29:40 PM(UTC)
kanks
doing the same but 307 t/700 box have some spares if u live nsw
nick ht Offline
#4 Posted : Wednesday, 21 February 2007 11:54:56 AM(UTC)
nick ht
thanks but in qld
may end up going sbc 350/383 crate motor
think i just need chev engine mount adaptors then ?
#5 Posted : Wednesday, 21 February 2007 5:26:20 PM(UTC)
Yep. Just look on Rare's online shop and you'll see them. And keep your eyes out for a HT/G trimatic shifter for the TH350, a HK-HG Saginaw or V8 Powerglide speedo cable and HT/G V8 Powerglide crossmember.
______________________________________________
This page was generated in 0.129 seconds.
