Hi all, Can anyone tell me the paint code of the HK Silver Mink Metallic please. I have come up with 587-1704 but this is only the shade # and the body shop cannot come up with the correct code. Your help appreciated. Regards, Glenn
Hi Glenn.
The 1150 number is the GM-H exterior trim code & this will be meaningless to a panel shop. He needs the Dulux paint number (1704).
If he can't mix it to the paint number (1704), it is probably because some of the tinters necessary for the |
THE TAGS ON MY SILVER MINK MONARO HAVE 567-1704 567 MEANS METALIC
During HK production the paint type changed that is why there is 2 prefixes. As stated in another post there are 2 codes for Warwick Yellow the only difference being the prefix.
Earlier solids were, 585 and newer ones 568.
Earlier metallics were, 58 |
You only have to be in front at the end of the race. |
