#1 Posted : Monday, 3 April 2006 10:51:12 PM(UTC)
Hello all,
I know that Commodore sedans use a different diff housing to their wagon counterparts but what else is different about the rear suspension?
Could you fit the lower control arms off the back of a VL or VN sedan onto a VL wagon? Are the shock absorbers interchangeable between sedan & wagon?
Thanks, Jim...
#2 Posted : Monday, 3 April 2006 11:54:45 PM(UTC)
Arms you can - they vary slightly in length depending on model & suspension.
The shocks are not interchangeable - the wagon ones mount on studs welded to the diff, the sedan ones bolt thru U-brackets.
_______________________________
#3 Posted : Tuesday, 4 April 2006 12:03:12 AM(UTC)
Thanks Mick.
