Fastlane
Holden Forums
Holden General Discussion
VL Commodore rear suspension differences
Hello all, I know that Commodore sedans use a different diff housing to their wagon counterparts but what else is different about the rear suspension?
Could you fit the lower control arms off the back of a VL or VN sedan onto a VL wagon? Are the shock absorbers interchangeable between sedan & wagon?
Thanks, Jim...
Arms you can - they vary slightly in length depending on model & suspension.
The shocks are not interchangeable - the wagon ones mount on studs welded to the diff, the sedan ones bolt thru U-brackets.
Mick _______________________________ |
Fastlane
Holden Forums
