Hi guys im currently stripping a spare 308 that i just bought and cant get the camshaft out. I have pushed the lifters all the way up and removed the braket at the front but the cam still wont come out. IT moves back and forth about 5mm but thats about it. Is it ok to lever it out with a screwdriver etc? Any help would be appreciated.
Not the BLOODY Kingswood |
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Have you removed the dizzy and fuel pump? |
all that remains is the cam. everything else is out. This engine has apparently been sitting around for quite a while
Remove the cam bearing tunnel welsh plug at the back and see of you can tap it out with a wooden dowel and a hammer. |
